obtain images from webcam
Hi everybody.
I need to get video from my webcam and then capture frames from this video.
Can you help me?
Thanks!!!
(3,223 Views)
Hi Ivan,
there exists a driver for USB-Cameras.
It should be possible to use this to grab the pictures.
This driver is not supported by NI and not investigated anymore. So if you have some questions about the driver you only can ask in the forum for some help.
En general you should be aware that the pictures of a webcam are bad quality and for a industrial aplication its far to bad.
I hope this helps you,
Greetins, RMathews
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
(3,192 Views)
Hi RMathews.
I had read this in the forum, but it gives me problems installing. The message is "You must have vision 7.1 or higher with labview 7.1 or vision assistant 7.1 or higher installed".
My labview version is 8.2.
¿What is the problem?
Iván.
(3,173 Views)
Do you have vision installed? As my informations are, you need it to use the usb-driver!
Regards
Ramona Lombardo
(3,134 Views)
No, i have not installed vision, but i thought that it was not necessary.
Thanks RMathews,
Ivan.
(3,118 Views)
