often Error in "memory.cpp" line 593
Hello All
I am quite often getting fatal error in "memory.cpp" line 593. It happens erratically, after different actions, not in pattern.
What does this error mean? Where can I start looking?
My program deals with Database toolbox, Jet4 engine.
I have LV 7, dell dimension 8100, 500MB, 1.5 GHz.
Thanks in advance.
Pawel
(2,750 Views)
Hello Pawel
When you get an fatal error in LAbVIEW you can enter the www.ni.com/failure site and enter your failure and it will give you some similar failures with possible causes.
To be able to help you some more on the specific failures you have expearenced you would have to be more specific/detailed on whats happening in the VI and what you are doing until you get the failure.
Regards
Mo
(2,750 Views)
