ogic smtp library example
Hi smercurio,
 first of all and although we're on 9th of January, I hope you have a good New Year.
Just related to ogic_smtp library I've been checking the different vis' and since I'm able to see the only vi you modified is SendData.vi, for sure you have modified other ones but I'm not able to see them.
thanks for your feedback smercurio,
kind regards.
Jose.
Message 11 of 29
(6,330 Views)
There was at least one other VI that I modified, but I don't remember the name of it, and I don't have the code in front of me.
Does it at least work?
Message 12 of 29
(6,321 Views)
Hi smercurio,
 yes,yes it works perfect. Just one word, thanks. Thanks so much for your time, support, feedback and sharing your code.
You know, in case you decided to visit Barcelona, here you have a friend Smiley Wink
kind regards,
Jose.
Message 13 of 29
(6,310 Views)
Excellent. Great to hear it worked for you, and thank you for the offer. Smiley Happy
Message 14 of 29
(6,306 Views)
Hi,sorry to trouble you that i  receive the text mail such as the following without  attachment.Why?
BTW,what's the limit about the attachment?The attachment in my vi is a txt file named 1.txt,and no more than 10kB.
X-Mailer: LabVIEW OGIC_SMTP Mailer
MIME-Version: 1.0
Content-Type: multipart/mixed;
 boundary="=====================_3268708019==_"
Status: RO
Message in MIME format
--=====================_3268708019==_
Content-Type: text/plain
 charset="us-ascii"
 format=flowed
Content-Transfer-Encoding: 8bit
This just is a Test.
Content-Type: application/octet-stream;
 name="1.txt"
Content-Transfer-Encoding: base64
Content-Disposition: attachment;
 filename="1.txt"
NTg2NTgyNzI0MjQyNTQzMjUyMzUz
--=====================_3268708019==_--
Thanks.
Labc
Message 15 of 29
(6,201 Views)
Hi
I have a similar problem. I tried the OGIC smtp library and smercurio's code but it doesn't seem to work. I can send emails to recipients in the same exchanger server, but whenever I try to send an email to someone on a different server (ex. gmail) I get an error:
CLIENT:   RCPT TO:<xxx@gmail.com>
SERVER:  550 5.7.1 Unable to relay for xxx@gmail.com
Any ideas?
thanks
Message 16 of 29
(6,124 Views)
I no longer had this thread on my watched list given its age. You should create a new thread posting the problem. Offhand it looks like the problem isn't with the library, but rather the Exchange Server. The unable to relay is basically telling you that the Exchange Server isn't letting you send mail to another server through it. As I said, this is an email routing issue, not an issue with the library.
Message 17 of 29
(6,117 Views)
Thanks for the answer. I'll see with the IT guy if he can do something.
Martin
Message 18 of 29
(6,115 Views)
I have the same error like labc and don`t know what I´m doing wrong???
When I send an Email with the Ogic Library I recieve following Email without any File Attachment::
MIME-Version: 1.0
Status: RO
 charset="us-ascii"
 format=flowed
 name="1.txt"
 filename="1.txt"
I'm using smtp.gmx.de and it works on Smtp-Test-Server-Vis...
Can somebody help me???
Please!
I will also open a new Thread with this Problem
Message Edited by Jaehter on 12-12-2007 03:37 AM
Message 19 of 29
(6,040 Views)
MIME-Version: 1.0
Status: RO
 charset="us-ascii"
 format=flowed
 name="1.txt"
 filename="1.txt"
In fact you have the attachment here. It is the last part contained between the lines --=====================_3268708019==_--.
Your problem is that somehow somewhere, there seem to have been -- added to the begin an end of the boundery indicator.
If you look in the header there is a line:
This is without the -- at the beginning and end and probably is the reason that the mail client can not recognize that there are\
multiple parts in the mail body.
Rolf Kalbermatter
Message Edited by rolfk on 01-25-2008 08:35 AM
Rolf Kalbermatter  My Blog
Message 20 of 29
(5,935 Views)
