oheapmgr.c
I'm trying to create an exe file frm a labview 5.1 program. I have this message: oheapmgr.C line 60. I have already created an application with the same program, I just modified the size of a comment window. Then I had this problem. I tryed many things but without any success. Could you please urgently help.
(2,792 Views)
The oheapmgr.c errors were fixed with the later version of LabVIEW. The problem usually occurred when you create a new object to be placed on the block diagram and adjust its dimensionality while dropping it.
Your VI probably got corrupted, and you should probably be able to fix it by changing back the size of the comment window. (do you refer to the Context Help window as the comment window?)
You can email NI support team with your VI, and they can test this behavior with the later version of LabVIEW.
Zvezdana S.
(2,792 Views)
