old pixelink driver can not be used in labview2009
I can use the pixlink driver SDK 4.2 in Labview 8.5 (8.2 samples from Pi). but there are always .ctl errors in Labview2009 as the screenshot below.
is there a new Pixelink dri for labview 2009 to be downloaded or how can I do with this problem?
thanks
(2,961 Views)
Accepted by topic author happygrw
Have you installed labview 2009 after you installed the driver? Can you please try to install the driver again and then check if still the same problem.
Stefan
(2,930 Views)
Do you know what version of our SDK you are using?
I have also attached a sample projest supplied from one of our customers.
Thank you,
Michael Ogilvie
Application Support Specialist, PixeLINK
3030 Conroy Road Ottawa, ON K1G 6C2
tel: 613.247.1211 x 242 | cell: 613.302.9844 |fax: 613.247.2001
http://www.pixelink.com
(2,758 Views)
