on off time
I need genarate True and false every 30 mins for 100 cycle. Is there is any example available for this purpose?
Can you help with this sample code?
I am using labview 7.1.
Thanks for your help
Message 1 of 10
(4,796 Views)
what is it ur trying to do with the data after u get it.
all u need to do to is have a for loop (for 100 cycles) and in it have a wait for 30 minutes then either put out a true or a false.
Message 2 of 10
(4,787 Views)
Every 30 mins need to save the data. If there is true it will save the data. This is going to be a input of save data.vi
Jey
Message 3 of 10
(4,784 Views)
Just use the Elapsed Time function on the Time & Dialog palette. Set it for whatever time you want and when that time has elapsed, the output "Time Has Elapsed" will go true.
Message 4 of 10
(4,780 Views)
I try with for loop, it not seems work for me. May be I am going in different direction. Please guide me.
Jey
Message 5 of 10
(4,775 Views)
I tried with elapse function, and it always true. It never be a false.
Thanks for your time.
Message 6 of 10
(4,774 Views)
Is that possible to give me the code for this.
I am appreciate for your help.
Jey
Message 7 of 10
(4,773 Views)
I am waiting for your response.
Message 8 of 10
(4,755 Views)
I don't know what you could be doing wrong. Putting the function in a while loop is all that it takes.
Message Edited by Dennis Knutson on 12-15-2006 09:59 AM
Message 9 of 10
(4,747 Views)
Thank you for the support.
I appreciate the help.
Jey
Message 10 of 10
(4,736 Views)
