onboard accelerometer FPGA myRio
I was wondering if anyone had any suggestions for code for the onboard myRio. I can not find any real examples or help, all I can find is information for the compactRio. Any help would be appreciated.
(5,103 Views)
Hi Gotti_uncc,
There are quite a few examples here:
NI Community Examples: myRIO
https://decibel.ni.com/content/community/academic/products_and_projects?view=documents#/?tagSet=1869
Not sure if any of those use the onboard accelerometer, but there's probably enough to get you started.
Tom L.
(5,098 Views)
Hi Gotti,
If you have LabVIEW myRIO installed, you should be able to access tutorials from the LabVIEW myRIO Splash Screen.
If you click on Set Up and Explore » Access Getting  Started Tutorials
This opens up a webpage. Click on the Your 1st NI myRIO Program. I would then follow this tutorial. Once you click Next on the bottom of the page, you see the onboard accelerometer collecting data.
This tutorial walks you through setup of the NI myRIO and your first program!
Sunaina K.
Product Marketing Manager for CompactRIO & TSN
Making the intangible, tangible
(5,063 Views)
(4,901 Views)
