one click select object on Front panel
   LabView7.1. On the front panel, I cannot select an object by one left lick. Where can I change the setting?
Thank you!
Weitong
(3,276 Views)
Hit the tab button to select "Selector Tools".
Or goto windows>>Show Tools Palette. which displays you the tools palette, Set the Automatic Tools seletion to True.
Now you must be able to select/move the object
(btw- Were you able to do it by multiple clicks?? Smiley Wink )
(3,273 Views)
   How to set the automatic selection tools true? My tools palette is shown, and I selected postion/size/select tools. But, still doesn't work.
 When I double click the object on Front panel, it opens a new front panel with that object instead of locating that object on Block Diagram.
Thanks.
Weitong
(3,265 Views)
In the tools palette, the LED on the top must be glowing. This indicates that you have selected the "Automatic Tool Selection"
It is opening the Control Editor panel because You have checked the "Open control editor when Double click" to true as shown in figure.
Goto
Tools>>Options, select front panel from the dropdown menu and uncheck the "Open the control editor with double click"
Uncheck it.
(3,258 Views)
Two things to remember.....(you can take that as hints Smiley Wink )
1.  When similar behaviour appears on the front panel/block diagram which makes you feel uncomfortable, go to tools options and glance around.
2. When you think that you cannot set a particular property for a control/Indicaor, last but not the least option is to right click on it.
Ahh... there it is... Thats what I wanted!!!!!! Smiley HappySmiley HappySmiley Happy
Message Edited by Vsh on 04-07-2008 12:07 PM
(3,251 Views)
I got it.
Thank you very much!
Weitong
(3,235 Views)
