one producer two consumer loops, dequeue same element in both consumers
Hi!
What is the best way for the following:
I enqueu data in my producer loop. I need this data dequeue-d in both of my consumer loops, but I want to dequeu the same element in both loops.
Of course if I put dequeues in both loop, then the second consumer loop will loose the odd elements and the first consumer loop will loose the even elements.
thanks!
Message 1 of 10
(5,295 Views)
Accepted by topic author Blokk
either create two queues or use notifiers...
Message 2 of 10
(5,286 Views)
just one more question:
My two consumer loops have a very fast loop cycle time, and the producer loop has a slow loop time (many GPIB reads).
In this case because there is no danger to loose data, Can I just replace the queue structure with Notifiers? So I do nod have to use two queues...
Thanks!
Message 3 of 10
(5,276 Views)
Hi Blokk,
"no danger" is quite optimistic in software development, but in this case you may use notifiers...
Message 4 of 10
(5,262 Views)
I see 🙂
The master loop has about 12 seconds loop time, and what I do in the two slave loops with the data, will take no more than 1 second.
Thanks very much for help! 🙂
Message 5 of 10
(5,259 Views)
@Blokk wrote:
Hi!
thanks!
Makes very little sence- that is, the problem is stated in such a way as to preclude an informative response
Gerd wrote"
Usually, Gerd gives good advice but on this one I'm going to pick on him just a bit- I bet he rushed in just a tad without thinking about the premise of the OP's question - and Gerd I don't mean to sound mean, my appologies
The question pre-supposes that to use a queue element twice in parallel it must be read twice.  This is false and led to less than optimal advice.  What about a template like shown in this snippet?
We can certainly dequeue once and spawn as many independant actions as we need within a single consumer loop!  Much more scalable than creating a queue for each action.
Message 6 of 10
(5,219 Views)
A notifier however is a very effective way to broadcast a message to multiple listeners. Notifiers also scale very easily.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 7 of 10
(5,214 Views)
Now I work with the notifiers, but thanks very much for the nice and simple idea with the queue! 🙂
Message 8 of 10
(5,205 Views)
Certainly correct!  and with the OP's situation where the consumers are faster than the producer a fine choice for now.  when the relative speeds become closer the notifier solution can loose data.  I intended to provide an alternate method for more general application.  Thanks for the input
Message 9 of 10
(5,195 Views)
Everyone,
loose = not tight
lose = not found
Smiley Wink
Message 10 of 10
(5,181 Views)
