one single graph for all types of data
 I have a program that loads a different subVI into a subpanel for each button selected. all subVI display some data in either graph /chart/digital waveforms/ mixed signal graph.
i was wondering if there is a single graph that can display anytype of data if customized. i want to get rid of subpanel design and just run the subVI call and display into the same graph.  i want to eliminate maintaining so many graphs in each subVIs.
(2,978 Views)
One way of doinf it would be to have  a output cluster of graphs could write data too
(2,924 Views)
Another solution that is slightly more compact and reusable might be to make a X-Control that switches the visibility of the various graphs.  That way you could treat the resulting indicator like a new type a graph that handles each data type programatically internally.
(2,915 Views)
