online control
in page 4 there says :Install your application in a RAW PC and run it.
can anybody tell me what it's that to want running?
tanx
Message 11 of 15
(2,456 Views)
Dear marp84
                Raw Pc is nothing but Which one has connected to the hardware or Which PC is controlling the Application through some Protocol  thats the RAW PC.
Basically we will develope the Application in our Office PC and we will install in the Client PC as EXE with Installer thats the Word its mean. I think u are clear right?
Thanks ins advance
Prabhakaran.T.J
Sr.Instrumentation Engineer
LabVIEW ,RT,FPGA,DSC,
cRIO,DAQ,PXI,
Message 12 of 15
(2,431 Views)
i've try all of your message but i can't still remote front panel?
Message 13 of 15
(2,419 Views)
Let me see if i can make more sense of this.
You have the labview webpage created.
You can see the labview webpage from your pc.
You need to see it from the internet? Are you behind a router? Do you have port forwarding setup on the router for port 80?
If you cant ping the pc's IP (or routers ip) from the internet then you will never get it to work.
- A minute saved is a Minute earned!
Message 14 of 15
(2,312 Views)
Dear Chuttiprabha ,
I have gone through all the steps mentioned above. I just want to create such VI in which remote user can have a control on a single object (say tab control) i.e. remote user can have a control only on "Tab Control Container". The rest of the conotrol switches shouldn't be in a control of any remote user.
I actually have a temperature monitoring VI. I have created its html and it is finely visible from a remote PC. I have a "tab control" in my VI. First Tab contains the graph and readings. second tab contains the Logged data (spread sheet). I want to allow the remote user to switch between those tabs and copy the spreadsheet data whenever they wants to. How can I do that? Please reply as soon as possible.
Thankyou
Message 15 of 15
(2,178 Views)
