opc server
hi
can i used ni opc server 2013 for connecting labview 205 to delta plc?
(3,135 Views)
Here is the list of drivers that can be used and the PLCs they work with.
https://www.ni.com/en/support/documentation/supplemental/07/supported-device---driver-plug-in-list-f...
If the PLC you are using isn't listed you may still be able to use a driver for a standard protocol like Modbus.
(3,112 Views)
