open a wordpad application
I would like to find a way to programmatically open a wordpad application using labVIEW.
THanks
Olivier
(2,989 Views)
Try the VI (as input give the path to the application wordpad.exe).
Risotto
(2,966 Views)
 May I ask you to compile your VI in LabVIEW 7.01 version, because even if I have already found a way to make this by running a "command windows" window and attribuate the path of the wordpad, your solution might be more efficient in terms of ressources usage.
thanks again
(2,953 Views)
I couldn't export the VI to previous version. The most previous version is 8.0.
I sent you a screensho of the VI which is very simple.
Risotto
(2,943 Views)
