open_create_replace file.vi
I am a learner.I can not find these two functions.does somebody know these two functions and tell the path about them?
Thanks!!!
Message 1 of 8
(5,826 Views)
Hi alenter,
the first one is a DAQmx related function. The 2nd one is an old file function, use the new version…
You should ask your instructor when (s)he gives you those old hardcopies!
Message 2 of 8
(5,823 Views)
in attached vi u can see 2nd
Message 3 of 8
(5,809 Views)
My Labview version is 2014 and your example is based on labview 2015.Can you give me the lower version example.
thinks!
Message 4 of 8
(5,776 Views)
I just find the two functions on the book.And I want to know how to use these functions.so do you know how I can find these two functions.
thanks
Message 5 of 8
(5,773 Views)
hi,
attachement is labview 13 version..it will do
Message 6 of 8
(5,756 Views)
Message 7 of 8
(5,751 Views)
Accepted by topic author alenter
go through some labview tutorials on writing file to get better understabding of this....
There are  two ways to tell s thanks in forums : either give Kudos or  Marked Solutions
Message 8 of 8
(5,747 Views)
