open file that created on LabVIEW 7.0 EXPREES with LabVIEW 7.1 version
hi all,
why i can't open file that open/modified LabVIEW 7.0 EXPREES , in version  LabVIEW 7.1 ?
thank's all    🙂
(3,179 Views)
I'm assuming that the file you are talking about is a VI. Do you get any kind of message when you try to open it? Does the VI have a diagram? A diagram is required to open a VI in newer version of LabVIEW so that it can be recompiled.
(3,177 Views)
yes the file is *.vi .  tha file contain blok diagram.
the that i get is :ERROR.jpg
(i even can't open file in this porum:
http://forums.ni.com/ni/board/message?board.id=170&message.id=206190&query.id=195707#M206190
thank's
(3,166 Views)
The error means exactly what it says. The VI you want to open is a LabVIEW 8.2 version and you only have version 7.1. You can open VIs that were created with an older version of LabVIEW but you can't open VI's created with a newer version. You can download an evaluation version of 8.2 if you want to view it but you could only save it for 8.0. You might want to make a request to the forum to have someone save it as 7.1 for you. I only have the 8.2 eval version myself so I can't do it for you.
(3,161 Views)
Dennis,
please tell me how i can to save file on LabVieo 7.1  that will open on LabVIEW 7 express ?
which action i need to do ?
(3,156 Views)
File>Save with Options>Save for Previous. If you have anything in a newer version of LabVIEW that did not exist in the previous one, the save for previous will fail.
(3,149 Views)
thanks all.
(3,145 Views)
