open file with reference
@ Titou
Thanks alot but is it possible that you downgrade your example? I'm still using LV 8.0.1 and I couldn't open it.
regards
Yves
Message 11 of 17
(1,386 Views)
Ok, there it is.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 12 of 17
(1,384 Views)
Hi
I have modified the example_launch.vi and try to open the same subvi (test_run.vi) twice now.
I have set the test_run vi to "reentrant execution" and expected that this should create two result files. but there's still only one instance opened and one result file created!
What's wrong?
Thanks for any help
regards
Yves
Message 13 of 17
(1,363 Views)
Hello Yves,
when you open the reference you should connect the options input with 8 (for reentrant run)
Ton
My LabVIEW Ideas
Message 14 of 17
(1,360 Views)
Hi
Does anybody knows what happens when I create an executable? I guess the loaded subvi will also be *.exe. Or does this type of programming only works with *.vi.
Because I made an executable with test_run.vi and tried to run it again. And nothing happened... (The test_run.exe works fine when running in standalone.)
Regards
Yves
Message 15 of 17
(1,349 Views)
The path of an VI in an executable is:
my_exe.exe\thevi.vi
Ton
My LabVIEW Ideas
Message 16 of 17
(1,339 Views)
Hi
I didn't knew that it is possible to run a *.vi without LV.
Yves
Message 17 of 17
(1,312 Views)
