open file
Hello!!!   Smiley Surprised
How can I open a file using the pda module without opening a Windows window?
Just like labview windows does.
The file of given this format (read and file.zip)
Greta
(4,406 Views)
Hi!
Perhaps they have not understood my doubt.
I Work with modulate of pda and I want to work with a file of data. Not if this is possible.
Somebody has worked with fixeros and I modulate pda?
Thanks, Greta
(4,352 Views)
I'm not sure I understand the problem exactly. Does this help?
___________________
Try to take over the world!
(4,348 Views)
Hi.
I do not understand where they must be kept the files.
When the program 'run' in pda, as the file can be looked for?
Greta
(4,346 Views)
You can place the file inside the "My Documents" folder (or any other folder) and provide a file path of "My Documents\file.txt". That should cause it to be opened. I'm not sure, but I think that if you provide just the file name, it will be opened if it is in the same folder as the executable.
___________________
(4,339 Views)
Thank you very much.
Greta
(4,311 Views)
