open g vi in project folder
If I were using some open g vi, and I want to include those vi into my project folder, so that all my vi are under the same folder.  What is the best way of doing this?  Do I have to do a source distribution?
Kudos and Accepted as Solution are welcome!
Message 1 of 13
(4,011 Views)
I would recommend against that.  OpenG is a library that is easily installed with VIPM as packages.  Just leave them alone in the user.lib folder.
Message 2 of 13
(3,994 Views)
I agree. It would just make it harder to keep them up to date. You have VIs in vi.lib, instr.lib, etc.
Message 3 of 13
(3,987 Views)
That is a bit scary.  VIs in the Open G Library can certainly be dependencies of a project.  Projects, of course "Depend" on dependencies.
Now we get into HOW you want to use the tools!  As an example, I lately went into a new client, installed SVN and LabVIEW 2013, added, VIPM from the Getting Started Window and also installed the Viewpoint TSVN tool-kit, and the Open G libraries, and felt "I AM READY TO ROCK!" (It was a small project)
That set up my development enviornment.  Had I been working with multiple developers on that project .......... Either a VI Package or an SVN Repository OR a combination of them, would have allowed me to scale what and what scope of deployment was needed for libraries and components were appropriate for the development team without a claim that other tools were needed.  - For development!  (And really a "Source Distribution" is only there for a development reasons and,  their might be better options- since VIPM ships with LabVIEW I'll let Michael A. speak on the utility of Source Distro Builds and discuss if they are obsolete)
But, for Deployment.  ??? You should not need to add "Open G" to an app for a developed application, The VIs in the application are in the executable heirarachy.
So, can you elaborate on the original question please?
Message 4 of 13
(3,985 Views)
I do just that in a project, i include all vi's needed in the project (including user.lib and vi.lib) and do a source distribution. The point being that i only need the runtime on the target.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 5 of 13
(3,969 Views)
/y
You do not need the source distro on the "target".
HOWEVER: When you are in a less regulated industry I have seen simillar things happen.  So, let us chat about what you need.  I promise I will not pick on y'all for best practices.  (Although.....) but, there are other solutions.   They are not always "Painless" but solutions exist.
Message 6 of 13
(3,944 Views)
We can chat /Y
Message 7 of 13
(3,931 Views)
If all Vis are understand the same folder,  If the folder is moved to another location, it will contain everything a program needs, and no need to install anything.  I have seen this done, and I probably wont' do that, but I am just wondering what is the best way.
Message 8 of 13
(3,888 Views)
Accepted by topic author jyang72211
The best way is to have OpenG installed on every LabVIEW develoment machine in the world...okay well maybe a little high hopes.
I understand the want to have easy portability and having a single folder with everything in it makes it easy for sure.  But I must recommend what others have suggested.  If you have a professional license of VIPM it makes it easier because you can perform an audit and have it scan which packages a project uses, and roll them all up into a single file.  Then when you want to move your project you take your folder of VIs, and this one configuration file (VIPC) and after installing the VIPC you can open your code and have it all not be broken.
Message 9 of 13
(3,880 Views)
What exactly do you mean by "another location"?  Another directory on the same computer?  Another computer?
It should be understood that if you are using a development tool for a project, then every machine that is developing that project should have the same tool(s) installed.
If it is the same machine, then there is no need to worry since user.lib is a central location.
Message 10 of 13
(3,854 Views)
