open office calc on Front panel
Hi Guys
I am trying to use open office calc with active X  but I cant seem to find the Active X (.ocx) file . can any one help me.
Also what I am trying to achive is that to have the OpenOffice Calc open on the front panel , I want to use the front panel to display the Open Office calc. Any one have an idea.
I am attaching a jpeg image of the front panel to be more clear , what I want to achive .
Regards
Regards
Message 1 of 8
(3,769 Views)
Hi nolsqn,
If you know where the .ocx file is on disk you can register it using the instructions from the link below:
http://digital.ni.com/public.nsf/allkb/4F811A9B23F1D46E862566F700615B7A
Kaitlin N.
Message 2 of 8
(3,714 Views)
Is the active x component definitely installed?
I seem to remember that it's a separate item in the installer, which is not selected by default.
Message 3 of 8
(3,701 Views)
hi
Thats the problem I donot know where is .ocx file , or While installing(open office) there was no option to install that too , where can I find .ocx file
Regards
Regards
Message 4 of 8
(3,664 Views)
When you run the installer, choose "Custom Install", then in the list of program features scroll to the bottom, expand "Optional Components" then enable the activex control installation. This applies to version 3.4.1, but the earlier versions were similar as far as I remember.
MC
Message 5 of 8
(3,659 Views)
hi
I just did that , but know I am trying to search for the .ocx extention and I cannot find it , becasue I want to regieter it
Regards
Message 6 of 8
(3,655 Views)
I believe the dll you need to register is so_activex.dll
Good luck
MC
Message 7 of 8
(3,649 Views)
Hi
I registerd that so_active.dll , but i cant figure it out , because i want to make openoffice Calc appear on the front panel , but this dll is not helping  .. do you have any example to help me ?
Regards
Message 8 of 8
(3,643 Views)
