open project file in signalExpress
Hi, all,
When I tried to open an existing SignalExpress project file copied from another laptop on my laptop, I got the following error message:
Installed component versions are not compatible with the version of the LabVIEW SignalExpress. Please install the latest versions of the following:
1) LabVIEW SignalExpress Shared Tools
I could not find this Shared Tools from the NI website. Any suggestions?
The verison of my signalExpress is 3.0.0.
Thanks a lot.
Cong.
(3,094 Views)
Accepted by topic author conglu
Hi Cong,
Depending on which version of Signal Express the program was written in, you may need to upgrade your version. Here is a link to all of the signal express downloads available on our website.
Cheers!
TJ G
(3,076 Views)
Thanks. I downloaded the whole package and installed it.
(3,063 Views)
Hi, I am with the same problem here and your link seems to be broken
 could you help please ?
(2,961 Views)
The link is not broken and in any case, you can go to the downloads page by clicking the Support link at the top of the page.
Also, you should post SignalExpress questions to that board. LabVIEW is the language used to create it and not many people here use it. We write our own applications instead.
(2,953 Views)
