open text file
hi im using labview 8.0 ...
i have a listbox which list all the text files in the folder.. and i able to this wit ni.
now my problem is let say i double click on the one of the text file  .. i want the text file to be open. how to do tis?
Message 1 of 19
(6,694 Views)
you can do this with activex
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 2 of 19
(6,679 Views)
here is a example hope it helps:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 3 of 19
(6,674 Views)
ITS NOT WORKING .. i need to open .txt type file..may be in notepad. how this is posiible?..
Message 4 of 19
(6,661 Views)
I was able to open txt files with this try putting this around the code:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 5 of 19
(6,658 Views)
make sure you put a time delay in that while loop
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 6 of 19
(6,654 Views)
You can use an ES to look for the List Box double-click event & use the Open/Create/Replace File function to open the double-clicked item (text file) of the list box.
- Partha ( CLD until Oct 2027 🙂 )
Message 7 of 19
(6,634 Views)
If you want the file to be opened in Notepad, you need to use the System Exec VI found in the Connectivity pallette & use the command line for launching Notepad application, which in turn will open the text file.
Message 8 of 19
(6,633 Views)
Don't shout at someone when you get an answer. Especially when your question is the problem in the first place. If you wanted to open the file with Notepad, why couldn't you simply have said that in the first place?
Message 9 of 19
(6,621 Views)
Im sry i didnt shout at anyone the caps in capital letters cos i on the cap lock and i dint change it cos my internet connection is bad. and im sry i post the question in the as i understand and im not good in english. im sry.
Message 10 of 19
(6,582 Views)
