open vi in the same window
hello,
is it possible to open an subvi in the same window like the main vi?
for example, if i open a vi by a button click the vi opens in a new window.
in some cases it will be better that the subvi is shown in an specfied area on the frontpanel of the vi.
markus
(2,844 Views)
Hi Markus
Yes this is possible. Use the SubPanel-Control. To learn about it, have a look at the examples. There's a nice one (viewer.vi).
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,840 Views)
there's a control called "sub panel" (located in the controlbox "containers" where you also find the Tab control). If you wire a vi reference to its terminal the front panel of that vi is shown in the "sub panel" control.
Regards Clemens
(2,838 Views)
