open vi reference by string in executable
@snp112 wrote:
I have a LabView Executable and I want to control it by python using activex control. When I use the method getvireference I get the error open vi reference no longer matches vis in memory. A filename is no longer sufficient because fullname of  vi has own libraries. What is the reason for this ?
It works for other labview executable. Can you help me in this matter.
Somewhere along the line the way VIs are saved in an exe changed The easiest way to figure what the fully qualified name is in the exe is to show the front panel of the target VI when it is in the exe and put an indicator of the FP showing the VI name.
Ben.
Message 31 of 31
(593 Views)
