open windows
How can I get a list of open windows in LV 2011, windows 7? I want to check if a certain folder/window is open, such as "C:\tmp".....
I suppose is rather simple but I need to refresh myself in LV now... 😐
(3,356 Views)
Accepted by topic author Haddock01
(3,337 Views)
Thank you. That worked. Great! But the LVwutil32.dll is not working correct under LV 2011 is some cases. But it solved the problem I was facing. 🙂
The LVwutil32.dll has a vi that make a window topmost, that don't work in 2011.  I worked alot under 7.1...I think much is solved if I could find a good documentation for user32.dll. Have you seen some PDF or something?
Thanx  again
(3,327 Views)
I have not had a problem using it. Perhaps it's the specific window you're trying to manipulate.
msdn.microsoft.com
(3,323 Views)
Now I know. Typical.!!  The user-folder with all the shortcuts has my "name". It is located under C:\user\<name>. THAT folder can't be controlled by lvwutils32.dll. Any other folder, but not that one - as I can see. You said that the dll was working for you. That was good to here for me. Thanks again.
(3,315 Views)
