openG WinZip
I've tried to compressed some directories and subdirectories with the WinZip OpenG tool using the "ZLIB Compress Directory" subvi. I can compress without problem but when I try to descompress with WinZip it appears an error message. It seems it fails one file. If somebody has used this tool and can send me an example it would be great.
Thanks in advance,
Angel
(3,234 Views)
Angel Olivares wrote:
> Hi,
> Thanks in advance,
What error message? I did quite some tests with LabVIEW ZIP library
before releasing it. If you can give me more information I would like to
try to fix it. That is unless it is a path problem. Winzip may be picky
with certain characters in file names.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(3,234 Views)
