openG Zlib library not working in Labview 2018 64bit
The link to the beta version seems to be dead. Do you have the 64 bit library available somewhere else?
Message 21 of 30
(4,402 Views)
Hi Rolf,
 I ran into the same issue as others with the Open G 2018 64 bit version so I follow the link that is provided in the solution however there are no files available for download. Can you check the link you've provided?
Message 22 of 30
(4,376 Views)
You need to be logged in to download the file. I would attach it here but it won't let me.
Message 23 of 30
(4,357 Views)
Thanks Cranky, That did it.  🙂
Message 24 of 30
(4,346 Views)
Were you able to get it installed?
Message 25 of 30
(4,326 Views)
Hi Rolfk,
I have to download your ZIP Library, in Labview x64 compress function works well, but I'm having a problem with uncompress function:
"The function name specified for this node cannot be found in the library. Right-click the Call Library Function node and select Configure, then choose the correct function name."
So, it seemd that library don't have lvzip_uncompress function.
Could you please check library? Maybe there is something wrong with my platform?
Message 26 of 30
(4,225 Views)
Which version did you download? From where?
The export is called lvzlib_uncompress and should be present.
Rolf Kalbermatter  My Blog
Message 27 of 30
(4,219 Views)
I have to download oglib_lvzip-4.1.0-b2.ogp from this link
Message 28 of 30
(4,207 Views)
You should try this link instead: https://lavag.org/topic/21142-openg-zip-42/?do=findComment&comment=128922
Message 29 of 30
(4,194 Views)
Thank you! This version works!
Message 30 of 30
(4,163 Views)
