opening all vi
I am trying to open a LabVIEW project, and it tried to load a lot of vi.  VI that I don't believe are needed in the project.  It tried to load so many vi that my PC ran out of memory.  why is that?  I didn't create that project, so i don't know much abou it.  Thanks!
Kudos and Accepted as Solution are welcome!
(2,679 Views)
the file in the project directory   blahblah.lvproj is actually an xml file. If you make a copy somewhere safe, rename it to blahblah.xml you can open it, with a browser window, XML Notepad, regular note pad, and see what files it thinks are part of the project. That might help you figure why it is trying to load so many.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,673 Views)
