opening configuration files
In my application I have a "configure" item in my menu. When this menu is selected, a doc/exel/txt file should open. It should have a format something like shown below:
S.No Pin No. Channel Name
Under each of the columns, the user will enter the required values and I need to use them in my program. If opening a file with predescribed format is not possible, then I would like to know how to read the data column wise if, such a file already exists.
Thanx & Regards,
Srini
(3,313 Views)
you can try using either read from spreadsheet.vi or read lines from file. you should be able to read your config file with out any problems...
Dan
(3,313 Views)
Hi srini,
See when u do something Like opening a file and asking the user to enter the details,u will not be able to do any error trapping ,ie if he enters some crap what will u do,so why dont u make a user interface ur self and ask the user to enter the data,this u can write to a spread sheet and later read from it for ur use.
(3,313 Views)
Hi Vicky,
Thanx for the idea. Ithink this wuld be a good option. But I would like to know whether LabVIEW allows an application to open a word/exel document for editing by the user.Is it possible?
(3,313 Views)
srini wrote:
> Hi Vicky,
Only through Active X and you need to have the actual Word or Excel
application installed as well. The Active X interface of Microsoft
application frequently changes between versions so you need to modify
LabVIEW programs regularly whenever you install a new MS Office application.
The Word/Excel file format is binary and very complicated and not suited
to be opened directly by LabVIEW. Also its documentation is sort of
limited and its file format changes even more than the Active X
interface of MS applications.
Rolf Kalberma
tter
Rolf Kalbermatter  My Blog
(3,313 Views)
