opening version warning
Is there a way to make LV give an advance warning before opening a VI that is from a previous version?
Perhaps my search skills are lacking, but I cannot find a posting on this issue.
Jim
LV 2020
Message 1 of 9
(4,340 Views)
LabVIEW doesn't do that.
You can use an application invoke node (Get VI Version) to find out what
version a vi was made in, before opening it. But that's all.
Wiebe.
Message 2 of 9
(4,321 Views)
That BITES.
Jim
LV 2020
Message 3 of 9
(4,317 Views)
You might wish to add your opinion and reasoning here.
___________________
Try to take over the world!
Message 4 of 9
(4,308 Views)
Thanks tst.  I hadn't found that thread ... I need to improve my search skills Smiley Wink  Unfortunately it won't help me with my LV5, 6.01, 7.1, and 8.0 work.
Jim
LV 2020
Message 5 of 9
(4,294 Views)
You can also submit a suggestion in the Product Suggestion Center.
Message 6 of 9
(4,290 Views)
You would think that this could be easily implemented, sort of a LabVIEW launcher.  We know that the system knows, because in the run time environment, it has to utilize the correct runtime version.
This morning I have played around a bit, I can see where the version is identified, but it is not a fixed offset I also only have LabVIEW versions 8.2.1 and 8.5 on my system, and have not looked at older VIs, nor have I tried to identify which versions of LabVIEW are installed... which should be a trivial task.  I am trying to look for a common header to the version, and may be onto something... but I need to pull out the old disks and load up some older versions and take a peeksy, and see if they changed something. with lvlib, & proj, they are identified in XML so that would be a piece of cake.
Anyways, I will poke around some more when I have some more time.
Paul
Message 7 of 9
(4,277 Views)
As I mentioned in the other thread, it would probably be easier just to write a tool which uses the method described earlier.
___________________
Message 8 of 9
(4,253 Views)
would need to check to see if it recognizes old old versions Like 3, 4, 5, and 6...
I can look into that in a bit.
Paul
Message 9 of 9
(4,249 Views)
