opening vi in sub panel
hello,
i think question has been posed multiple times but i don't find post talking about behavior expected
i have two vis that can be called vith a main i would like to call them using arguments (init, stop, ...) but
as they are played alternativitely  i would like to see panels not in new front panel but in  common sub panel of main ...
 Best regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(3,560 Views)
Hi
There are some good examples on how to do this in LabVIEW help.
Go to 'Help>>Search the LabVIEW Help' and under the index tab browse for 'subpanel controls, inserting a VI' there are then three or four examples on loading sub panels inside a VI
Hope this help
David
www.controlsoftwaresolutions.com
(3,528 Views)
Thank you
me again
there is no way to display   for example vi1 or Vi2  in a sub panel without caliing them with there explicite filename ?
i'm interested with sub panel not for dynamic calling but for common window of vis   used in a main prog
Best regards
tinnitus
(3,503 Views)
Hi tinnitus,
Not exactly sure what you're asking.  What is wrong with dynamic calling?  The Insert VI in SubPanel requires a VI reference.
Have a look at the LV shipped examples.  Try to search this forum.  Easy!
Cheers
Battler.
(3,483 Views)
