operator interface does not open the sequence it is programmatically told to open.
Useful information
Windows 11 enterprise
LV 2022
TS 2021
Operator Interface used to call a TestStand sequence file.
Something unexpected is happening with operator interfaces and teststand sequence calling.
I have 5 operator interfaces that each are programmatically told to open a specific TestStand sequence file.  I am using an invoke method on the Application Manager to set the sequence file to use that is saved in a control of that OI top level VI.
This works fine immediately after building the OI for any of the OIs involved.  After that, the TestStand sequence file called from any of the OIs already built will be the last sequence file that was run, not the one set with the invoke node.
Four tests use the same OI with a different top level VI each which calls a different sequence.  One OI is different from the others, but acts the same, it will use the last sequence called, not the one it is told to use.
Why is this?  I have been banging my head against a board about this.  Is the application manager saving state somewhere I can get to?
be well,
DLC
Message 1 of 9
(1,813 Views)
Update.  No, even after I build a new OI for another test, the last sequence file run is still selected.  This is a problem since I have 5 project OI's built, but I have to "do something I have not quantified yet" in order to get the project's required sequence file to be run.
be well,
DLC
Message 2 of 9
(1,739 Views)
I am closing this question here in LabVIEW, because the "flip" occurs after the TestStand RTE gets fired up, I think this is coming from something that TestStand is doing, not my LabVIEW OI build.  I am moving this question to TestStand.
For those interested, the TS question is here:
https://forums.ni.com/t5/NI-TestStand/TestStand-engine-does-not-run-the-sequence-an-OI-tells-it-to-r...
be well,
DLC
Message 3 of 9
(1,665 Views)
I am now back to thinking it is a LabVIEW bug after more testing. The LV code opens TS before setting the sequence file, which makes sense. The Invoke Node for the Application manager that opens the sequence file is what changes the file to be opened, not TestStand.
Single-stepping through the code, it runs correctly, running full out, it does not.
Adding delays doesn't change anything when running full speed.
This must be a bug and I'm done with it. Hopefully NI2025 fixes it.
I'm done with it until I get a NI2025 RTE license on a test computer.
be well,
DLC
Message 4 of 9
(1,648 Views)
To things that I can come up with.
1) Are you closing the TestStand session correctly when you close the OI ?
2) Have you tried to unload all files before loading in the new file ?
Application Manager has a method for closing the files: ApplicationMgr.CloseAllSequenceFiles()
 There is also a ActiveX component that can display the loaded sequence files.
Message 5 of 9
(1,619 Views)
I am using a flavor of the simple user OI that someone created years ago and I have migrated to a newer NI version.
I am properly closing the OI.  I have checked and there are no rogue threads running.
I do close all sequence files.  I have singled stepped through it and it works as expected doing that, but if I let run "full speed" it does the "I will ignore what you said and do what you did last time". I've attached the string of invoke nodes used.  I'll not put it in the message here because that is never legible on a screen.
be well,
DLC
Message 6 of 9
(1,599 Views)
Did some check on what I normally do.
I think the main problem is that you are loading the sequence file too early.
Under normal operation, a user has be logged into the TestStand engine before you can load a sequence file.
How are your user logging into TestStand or do you setup a default user ??
Message 7 of 9
(1,590 Views)
Thanks for the reply.  I have TestStand automatically login as the windows user.  There is a special Windows user for the test stands.
be well,
DLC
Message 8 of 9
(1,583 Views)
It should be possible for you to verify that the user is logged into TestStand before loading the sequence file.
Message 9 of 9
(1,545 Views)
