opposite data reporting
I am having a problem with the reporting of data with my experiment. I want to grab a measurement at every 6 second interval, but when I put that in the front panel, it instead grabs all the data inbetween 6 seconds.
Anyone know how to fix this? I attached the vi.
Thanks!
(3,397 Views)
Accepted by topic author kmarcella
Change your Not Equal to 0   to Is Equal to 0.
I would use the elapsed time function to determine when 6 minutes is up.  It makes more sense than tying your time to an iteration count for a while loop.  Suppose later you change the pace of data?  Then the number of iterations needed for 6 minutes will be a different number.
PS.  You don't need two index Arrays to index out element 0 and element 1 of the same array.  Just use one and drag the bottom of the function down 1 step.  It will give you two outputs, element 0 and 1 automatically without needing to wire in any index constants.
(3,376 Views)
