optimization of function with discrete (integer) arguments
Given: a matching unit (MU) with 2 motors which are controlled via RS232. Each motor can be driven to position from 0 to 1000 (integer only!).The value to be optimized is mismatch, which can take value from 0 to 100% and depends from the process (considered as external influence) and the MU motor positions (X1, X2).
The purpose is to get the perfect match, i.e. mismatch close to zero (from the practical point of view Mismatch<1% is zero). The dependence Loss(X1, X2) is from the experience rather well-behaved, with only 1 minimum, which is close enough to zero as a rule. However there may be some process noise, sometimes up to 1-2% mismatch.
I've tried (with a simulated process) the Constrained Nonlinear Optimization VI. It worked OK for floating X1, X2 values, but failed as I converted X1, X2 to integers. Is there any workaround with the ready-to-use LabVIEW VIs? We have LV full development system here.
What optimization algorithm would better suit for the task? If I'm to implement it myself, then is following to consider:
  • simplicity is strongly preferred
  • large changes of (X1, X2) values cost time
  • working with large mismatch should be avoided if possible
  • after the motors reached the position, th system settles immediately
(3,586 Views)
Hello Elkb,
how did you convert the Datatypes (Int => DBL)?
Regards!
Moritz M.
(3,572 Views)
Using I32-->DBL function
Attached is my test. By a switch you can turn on or off the conversion (i.e. rounding) of the arguments. Without rounding, the optimizer finds the minimum in just a few steps. With it, it actually never moves off form the starting point.
(3,557 Views)
I am no optimization expert, but I think I can explain why your integer mode version does not work.
I put a functional global VI inside the nonlinear test objective function.vi to capture the values of the output.  I called the functional global in Read mode in a separate VI to display the results.
objective output (DBL)(I32)
19350.530000000 19350.530000000
19350.531144018 19350.530000000
19350.529324858 19350.530000000
18931.496465206 19350.530000000
X[0] (DBL)(I32)
500.00000000000 500.00000000000
500.00000477470 500.00000000000
261.70422390905 500.00000000000
The conversion to integer rounds out the small changes in the first few iterations. This keeps the optimization VI from moving towards the optimum.
Explaining what happens is one thing. Getting it to do what you want is another.  Can you optimize with DBL, convert to integers, and calculate the values for those integers (and possibly near neighbors)?
Lynn
(3,548 Views)
Lynn
Thank you Lynn,
I've set up the global that way exactly with the aim to look what's happening.
The problem is, my aim is not optimizing some simulation, where I could use DBL (or even complex). In the end, I have a real world process, where I can only move motors in steps and measure (with limited precision and some noise) what's happening.
(3,532 Views)
I understand that you can only move in discrete steps.  My suggestion was to allow the optimization to run with floating point numbers and then move your motors the integer number nearest the floating point optimum.  Depending on your process, you might need to round down or up rather than using the nearest integer.
Lynn
(3,524 Views)
