If I have an analog signal (single-tone sinusoid) and I use it as my tach signal and send the same signal through the OAT Extract Order Waveforms (getting just the 1st order), should I expect to see an order waveform with the same peak-to-peak magnitude as my original waveform?
The signal of interest is 6Vpp (-3V to 3V). The 1st-order waveform is 3.6Vpp (-1.8V to 1.8V).
Since the 1st-order is the frequency of the original signal, it seems that the 1st order waveform magnitude should be the same or at least closer than 60% of the original signal.
Any information/guidance will be greatly appreciated.
Chris
