order analysis
Does someone knows where can I find examples and information about the order analysis tooolset?
(3,031 Views)
Contact your local NI sales engineer (or manager). If you do not know who that is, just call 800-IEEE-488 (NI). Ask you local NI guy to refer you to an Alliance Member who has likely used the Order Analysis Toolset to do some nifty things. We do like to show off sometimes. You may even find that we've done something very similar to what you're thinking and could implement it for you much faster and cheaper than if you're on your own.
We do this stuff every day.
Daniel L. Press
PrimeTest Corp.
www.primetest.com
(3,031 Views)
You can also take a look here [broken link removed]. That's the web page for the toolkit. But if you are interested, you should certainly contact your local NI guy or an Alliance Member.
J.R. Allen
(3,031 Views)
