organising data
Hello all,
Im a new labviewer and I was hoping for advice/help etc with this program im trying to make.
basically, I collect data from two channels through a DAQ card.  I want to manipulate and tidy-up the
resulting data using a labview excutable file.
The data I get from the DAQ looks like this
I cut the data at the peaks and valleys...organise the data so they overlap (they are mirrored
scans)....align the data by eye... then average the data.
I have done all that and was looking for advice on how to make it cleaner/faster or tidier.
Many thanks for all your inputs.
Hello all,
Im a new labviewer and I was hoping for advice/help etc with this program im trying to make.basically, I collect data from two channels through a DAQ card.  I want to manipulate and tidy-up the resulting data using a labview excutable file.The data I get from the DAQ looks like this
18105iA2ACF3EABA9FCCCE
(3,434 Views)
Why are you converting the 2D array to 3D in the chopper vi?  This seems unnecessary.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(3,394 Views)
Thanks very much for your input.
I added that conversion to make it possible to shift the array values when I am aligning the graphs on top of each other before I average them.
when i had it as a a 2d array i was unable to simply shift the components of the array by a certain size.
(3,374 Views)
