oscillscope project
are u asking for 100000$ ? make a friendly price , u said that it will take u 30 min to do all that before 🙂
similar or same one ? i did not see it yet
LV 8.2
Message 101 of 401
(1,845 Views)
I think it will take more than 30 min to fix everything... LOL! 😄
Wish there was a Private Messaging (PM) option available on the site..  I don't want to post our contact information because they would also be accessible by spammers and telemarketers...
I might change my signature temporarily to show my email address.. 😉
R
Message 102 of 401
(1,834 Views)
just make any VI and put in ur email 🙂
LV 8.2
Message 103 of 401
(1,831 Views)
Hi JoeLabView and kmous,
If you are trying to contact each other confidentially, you can both call me, and I can exchange your information.  There is a service request open with regards to this discussion forum posting at National Instruments.  The number to contact me would be 1-866-275-6964 with the service request number of 1166725.  Once both of you have called me, I can close the service request.
Just giving you one option,
Kevin S.
Message 104 of 401
(1,793 Views)
Thanks Kevin,
That's a great idea.  I was also going to suggest contacting the local rep.  But your way is much easier.
RayR
Message 105 of 401
(1,777 Views)
Thank you Kevin
But why it is easy since I can give up an email here ? and then remove it after a bit ?
and btw Joe , u are in Kanata , what's ur # ? 🙂 sounds easier ? put it and remove it back in 5 min, i always check the forum
Message Edited by kmous on 07-10-2008 12:15 PM
LV 8.2
Message 106 of 401
(1,773 Views)
Kevin is waiting for your call 😉
Message 107 of 401
(1,766 Views)
Hi kmous,
Here is the code with the change Dennis suggested.
I will make a small improvement to the architecture to change it to a COnsumer Producer loop with an Event Structure.
Such an architecture will allow you to add triggers more easily.
R
Message 108 of 401
(1,726 Views)
Hi Ray
I am using LV 8.2 🙂 I just implemented Joe suggestion in my VI , i am not sure if it is the same thing u did , i will check it once u save the Vi in 8.2
Thank you Joe
Btw i sent u an email this morning !!!
LV 8.2
Message 109 of 401
(1,724 Views)
Here is the updated version.
I have not tried the software as I do not have the instruments that you have.
Have a look at the program and post back any questions.
R
Message 110 of 401
(1,719 Views)
