oscillscope project
Wow... that's asking for a bit much..  😮
Here's an improved version which does not require an enter button, it is auto detecting..
Message 381 of 401
(2,427 Views)
No NO what i meant is I want them to see an ENTER button 🙂 that's all  is that ok ?
LV 8.2
Message 382 of 401
(2,425 Views)
Ray , I connot exit the GUI.VI , I want it to close completly when i push Quit. is that any function to force it ? or it is the exit one ?
LV 8.2
Message 383 of 401
(2,410 Views)
There must be something in the software that is not completing which is why it does not respond to the Quit request.
I did not investigate the code.  I would not use that architecture, but that does not help you...
Try running it with Highlight Execution turned ON and look at where the VI is executing when it does not respond to the Quit button.
Other than doing a major software overhaul which I have no time for, I'm sorry but I can't help you more on that one.
R
Message 384 of 401
(2,401 Views)
Why do you want an Enter button?  There is a checkmark that appears on the top left corner (below File menu).
Hitting the Enter key also works.  Why do you need an Enter button when it is not needed?
R
Message 385 of 401
(2,400 Views)
I Fixed it 🙂 Ray I am leaving Today at night , Thank you for the help , i will be back in 2 weeks i guess.
We gonna have to go back to the last VI we were working on it before , emg/force/signal
we had 2 things missing : the Trigger issue and the header problem (we want it to match the info they sent to me).
Do you want me to refresh the memory  a bit ?
LV 8.2
Message 386 of 401
(2,375 Views)
Let's wait until you are back.
I am quite busy these days...
R
Message 387 of 401
(2,369 Views)
Sure Thank you , any thing you need frm lebanon ? do you smoke shisha ? hookah(argili) ?
LV 8.2
Message 388 of 401
(2,361 Views)
I don't smoke anything  🙂
Just photos of the mountains and the sea..   😉
Have a good and safe trip.  Don't think of LabVIEW while you are away  😄
R
Message 389 of 401
(2,349 Views)
Hey Ray je suis de retour de mon voyage 🙂 was not that bad. il y avait beaucoup de monde qui ont decede dans le village la ou j'habitais mais bon c est la vie.......So how are you ?how is every thing ?how is the family doing ?  we should get back to work now.......
LV 8.2
Message 390 of 401
(2,222 Views)
