out and in port capability
Hello
I have executable file that was build in LabView. (LV 6.1 & Win 98)
The application use the parallel port by Out port vi .
I tried to copy the program to Win 2000 platform,
but it's produce error "capability not supported vi was stopped at node xxx"
what shell I do to work with this application ???
Theank's
Shaul Dotan
(2,826 Views)
Hello Shaul,
have a look on these two links.
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3DEBD56A4E034080020E74861
http://zone.ni.com/devzone/conceptd.nsf/webmain/72C6FC6CE4AD4D1386256B1800794596
I work with LV6.i on a Win2K system. After installing the "AccessHW Libraries" from the first link, I was able to do parallel output or parallel input operations. After installing these libraries I only had to change the original "out port" VI to the new one.
Regards ThomasD
(2,822 Views)
Hi
I can't replace the VI, because it is executible file.
I dont have the source.
T.U
(2,807 Views)
Look at this link!
If this is also not the solution for the problem, you could search for this topic under http://www.ni.com/support/. Perhaps you have luck.
Regards
ThomasD
(2,796 Views)
You've got a couple of options. Go back to the vendor that you bought the executable from and pay to have it upgraded for WinNT/2000,XP or change the Win2000 pc to Win98.
(2,786 Views)
