out port.vi Missing
I am upgrade in older application from Labview 2010 to Labview 2016
Also moving from Windows Xp to Windows 7
Everything loaded but the out port.vi and in port.vi can not be found
I download and installed most of the drivers I could locate
Where are these drivers located ??
My development environment is a new windows 10 64 bit machine
BrianD
(3,196 Views)
Hi Briand,
in/output aren't supported on newer Windows versions - especially not on 64bit versions…
Stick with LV2010 and WinXP if you need them!
(3,194 Views)
