Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
output of variant to data gives an empty output
indhu
Member
08-18-2004
02:26 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Hi all,
How to convert variant to string output? if i use 'variant to data' it gives out an empty string. I have attached my program (which is to store the image path into database and then retrieve it).Help me out to solve this problem.
image_db[1].vi 86 KB
0
Kudos
Message
1
of 4
(2,655 Views)
Reply
Re: output of variant to data gives an empty output
DOC-doc
Active Participant
08-18-2004
03:39 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I can't open you sub VIs and can't see how you define the structure of your variant
Doc-Doc
http://www.machinevision.ch
http://visionindustrielle.ch
Please take time to rate this answer
0
Kudos
Message
2
of 4
(2,655 Views)
Reply
indhu
Member
Author
08-18-2004
04:09 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Thanks for your reply i'm able to spot out my error and corrected it!
Thank you!
0
Kudos
Message
3
of 4
(2,655 Views)
Reply
DOC-doc
Active Participant
08-18-2004
04:21 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
No problem
Doc-Doc
Doc-Doc
0
Kudos
Message
4
of 4
(2,655 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
