output table
How to get the value output of 1.5 in the array table if the value range is between values 11-13?
(4,607 Views)
Accepted by topic author farah88
Add another element to the beginning of the first array.  Then use Round Toward -Infinity on the threshold index and use Index Array instead of the Interpolate 1D Array.
(4,599 Views)
thank you
(4,591 Views)
i still don't get the answer.
(4,574 Views)
You missed adding another element to the beginning of your first array.  Alternatively, you could throw in an Add 1 after the Round To -Infinity.
(4,558 Views)
