output the sbrio 9642 internal clock
In the NI sbRIO 9642 board, it has an original 40MHz internal clock signal. I want to use this clock signal to synchronize other components that is not the board.
I wrote a very simple vhdl netlist to do this job. Just invert the internal clock signal. But the output signal is constant, which is very strange.
Here is the vhdl code I am using
libraryieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity clockOut1 is
port(
      CLK : in std_logic;
      FOXB_CLK_OUT : out std_logic
end clockOut1;
architecture clockOut_arch of clockOut1 is
begin
       FOXB_CLK_OUT <= not CLK;
end clockOut_arch;
While in the LabVuiew block diagram, it is like that.
Yongxin
(3,608 Views)
Hi Yongxin,
Here is some information about using clocks with CLIP. There are also some examples of how to export the clock signal directly to a pin, which would remove the need for CLIP. Perhaps these documents can help you solve this issue.
How do you know that the output signal is constant?
Andrew
Andrew T.
"His job is to shed light, and not to master" - Robert Hunter
(3,521 Views)
If the goal is to export the default 40MHz clock, you could try deriving an 80MHz clock from the 40MHz in the project, then placing a DIO terminal in  SCTL that uses the 80MHz as a timing source and toggle the DIO line every iteration. Edit: Not sure this will work on the 9642. The DIO lines haven't been validated at frequencies above 10MHz.
Also, did you assign a clock to the CLK input from the CLIP Properties Page?
(3,508 Views)
@a_clucker wrote:
Hi Yongxin,
Andrew
Hi Andrew,
I use the IP Node method to export the vhdl code, but will try your CLIP method later. The 1st example you give is instersting, I will try it later.
I use the oscliscope to detect the output signal from the pin, it's constant ....
Thank,
(3,493 Views)
Hi David,
Sounds it doesn't work for that case that place a DIO terminal in the SCTL and output the clock signal directly. I will try your method anyway.
I didn't use the CLIP method, so no CLIP property for me.
(3,488 Views)
