outputing a dir listing for use as a file sorter
hi all
i was working on using an external *.exe to encode some data and i
need to take a dir listing in so that i can apply the encoding to
certain files, but i am having a little diffuculty in in outputting a
text file from which to scan, i have
i am using labview 6, and the main vi elements i'm using for this
proccess is the list dir vi index array vi and write chars to a file
vi, but i cannot get the file names on a new line for each one, they
are all after each other with one space....
i know in text based programing you can use \n or similar to solve
this, but i am at a loss here with labview
if any one could help i would be most grateful
peter
(2,806 Views)
Peter,
Here is a VI that does what you want. Basically, it uses the function Spreadsheet array to String to get the text string (with the file names) with line feed as a delimiter. This string is then written to a text file.
I hope this helps. /Mikael Garcia
(2,806 Views)
The string palette has constants for different linefeed, carriage
return, or the platform adapting en
d of line. If you add this
string character between names, that should get you started.
Greg McKaskle
(2,806 Views)
many thanks! i don't know how i could have missed that! 🙂
"Greg McKaskle" wrote in message
news:3C22A8B2.8020709@austin.rr.com...
> > this,
> return, or the platform adapting end of line. If you add this
> Greg McKaskle
(2,806 Views)
