owning library is missing!!!
Help!!!
What do I do to fix the " owning library is miissing" error.  I know where there are at least 2 versions of the library.  I only wich I could tell which onw has the changes I recently made.
LV 8.6 on Windoze XP
(3,208 Views)
Clueless-
I am not familiar with that error mesage, what were you doing when you recieved it? Are working with .lvlib's or .llb's?
Xaq
(3,185 Views)
lvlibs. And what I had done was remove them from the directory where they had been, thinking I could run the vi's from the folder structure in which they actually resided.  However, it seems that once you've linked them from within a lvlib, they continue to be associated with the lvlib namespace.  Now that I understand this, I know how to deal with it, and even though it's not exactly intuitive, I can live with it because the old way of a huge honking global namespace was a real disaster waiting to happen.  Trouble is, it reverts to the unpredictable (by me) global namespace if you click through the warning messages.  I wish this were better explained in the help system, and if it is I wish it were easier to find!
(3,178 Views)
