painful slow active X ????
I tried to use the automation vi's to access a large database application.
One dataset can be as large as 20000 double's and the database ole interface
only allows to access one number at a time. The sample programs for excel
and word run rather quickly but my labview code requires about 20 times more
excectuion time. Any ideas how to improve things? Are the ActiveX vi's that
slow?
klaus
(labview6.x)
(2,663 Views)
If OLE interface mentioned is so stupid and doesn't allow to get numbers in a reasonable quantity and speed, I'd suggest to search for another database application communication mechanism. Say, storing data to file or send through another communication channel like TCP/IP, DDE or anything else. This may be faster.
Generally there is LabVIEW SQL toolkit from NI and it's manual describes the right way of accessing database data in M$ Windows.
http://www.ni.com/catalog/pdf/1msw094_097a.pdf
http://digital.ni.com/manuals.nsf/7aba4d4ed8d9fa958625663500505c98/e2f21bc9809714f28625665e00635879?OpenDocument
Comment: When asking such a question, don't keep in secret the name of your database application and some additional details, and you'll get much more chances
to get the right answer.
Best Regards,
Sergey
(2,663 Views)
