pair off true and false
hi
i need to pair off an array of boolean, the following is the rules
1.pair off OFF-ON, not ON-OFF
2.pair from the beginning of array to the end
3.input is an array of boolean, output is the index of elements which haved been paired off
attached is an example
how can i do that?
thanks in advance
(3,885 Views)
Why are 6 and 9 paired off?
David
(3,874 Views)
Sorry, forget to mention that
this pair seems like the C grammar
{                                              // 1
          {                                   // 2
          }                                  // 3
}                                            // 4
so 1 must pair 4, and 2 pair 3
(3,872 Views)
A few more bits of info would be helpful.
Is your boolean array always the same size? Maybe, array size is odd, even or both.
How many F->T indent nest levels can there be?
David
Message Edited by David Crawford on 10-03-2006 12:52 PM
Message Edited by David Crawford on 10-03-2006 12:55 PM
(3,872 Views)
array size can be odd, even or both
the max nest level is 3
(3,862 Views)
