panel resize when program is executed
For some reason, when I select run the entire window resizes and I have to click the windows maximize screen button in the upper right hand corner.  Any suggestions on why and how to fix?
Thanks.
LabVIEW 2016 - Windows 7
CLAD
(2,844 Views)
Well, LV doesn't resize screens on its own (except to maximize them), and I've never heard of this as a LV bug. Try turning on execution highlighting and seeing where the resizing is happening.
Mike...
Message Edited by mikeporter on 09-07-2005 05:51 PM
Certified LabVIEW Architect
LabVIEW Champion
(2,834 Views)
If this only happens with a single VI this is probably becuase of something in your code.
As other options, did you change the window appearance settings? If you asked LV to center the VI, for instance, it will move it if it isn't maximized. There is a known issue in 7.0, 7.1 and 8.0 (at least the beta) for windows where the panel is resized if you set some of the window appearance options, run the VI and then undo, but this sounds different. If this happens with a single VI and you can't find the problem, I suggest you post it.
___________________
Try to take over the world!
(2,823 Views)
Have you checked VI*s properties?
In window size you can select option to max FP to fill whole screen
Also auto cente.
chow
xseadog
(2,816 Views)
