panes using splitter - error 1358
I've a problem using panes with a vertical splitter. When I wan't to scale only one object (a tree) in a pane I get the error 1358 when setting programmatically the splitter position. I am using it to expand/collapse the pane. Without using the option "Scale Object with Pane" on the tree object everything works fine but without resizing the tree object automatically. The error explanation says that I can set the minimum size of the pane but it is already set to 1/1. and I wan't to set the splitter position to 10.
What's going wrong in this case?
Best Regards,
Joachim
(3,936 Views)
Hi Joachim
Can you post an example VI ?
(3,905 Views)
Hi Neil,
sorry for the delay. Attached is an example with which the error 1358 can be reproduced.
Best Regards,
Joachim
(3,824 Views)
DId you get the problem solved?, I have the same error using the splitter
Regards
Image and video hosting by TinyPic
<script type="text/javascript" async src="//cdn.youracclaim.com/assets/utilities/embed.js"></script>
(3,708 Views)
