parallel counter operation
I am trying to use two counter from the same card in paralle. I have attahed the VI here. I used the example VI to generate finite pulses to prepare my VI. Iam using PXI-6722 hardware.
Can this operation be done? How to avoid the conflict?
Regards
Gopal
(2,678 Views)
Hello Gopal,
You are receiving this error because you need both counters on the device to perform a finite pulse train generation task. You can see this Knowledgebase for more information about the problem.
Matt Anderson
Hardware Services Marketing Manager
(2,655 Views)
